Total | 26,800.8 | 22,538.1 | 8,030.4 | 1,086 |
@Esmail Bro : Jio’s B5 (850 band) BW was always 5 mhz since beginning in UP (West). I believe RCOM’s and Jio’s B5 blocks were non-contiguous. Even before spectrum sharing agreement between RCOM and Jio ended in UP (west) Jio’s B5 was never 10 Mhz in UP (West). Now since after 2021 auctions Jio and Bharti Airtel both hold 5 mhz BW in Band 5 in UP (West). Can they deloy it as 10 mhz single block via spectrum sharing after 1 Year. Esmail bro can you please verify if Jio’s and Bharti Airtel’s Band 5 blocks in UP (West) are contiguous with each other or not ???
No, it is not exactly contiguous, There is a small guard band in between the two as you can see in the image I am sharing below
https://i.ibb.co/ngdLbrP/850-MHz-UP-west.jpg
So yes the spectrum sharing can work if DoT agrees to harmonise the holdings and remove the guard band from in between.
@Esmail Bro: Is this the current allotment scenario for B5 for UP (West) Circle ? I mean please refer the picture, the blocks alloted to RCOM are totally non-contiguous. How would RCOM utilise it as a 5 mhz carrier ? Moreover I don’t think DOT would harmonize Jio’s and Airtel’s blocks just for the purpose of spectrum sharing. Had it been Jio holding 2 blocks of 5 mhz non-contiguous carriers, then DOT would surely consider the harmonization option. Now is there any possibility of Jio making 10 mhz single contiguous B5 carrier in UP (West) circle through any option since both RCOM’s and Airtel’s spectrum is valid in B5 UP (West) for a longer period ? Also from where did you get the information as shown in this picture. The provisional results of frequency allotment to operators shared by DOT in 2021 spectrum auctions shows different frequency allotments than this to Jio and Airtel for B5 in UP (West). Please answer all the above questions.
The frequency allocated to Jio is the same as in the provisional results, Airtel’s allocation was slightly altered to ensure it gets a contiguous 5 MHz block, this is the current allocation as of today as per Saaral Sanchar wing of the Wireless Planning commission of DoT.
Yes, the allocation of Rcom is non-contiguous as most of it was originally held by MTS which had bought it in the 2013 auction for deploying it on CDMA and EvDO technology which didn’t need a contiguous 5 Mhz block, unlike 4G LTE. This spectrum was priced low by DoT since it was not intended for 4G use (even though it was liberalised) and DoT is purposely not making it contiguous so that it cant be used for 4G.
DoT has imposed a special condition on the trading of this spectrum, whereby if Rcom wants to sell it to say Jio, then it will have to pay the difference in the current market price of the 850 Mhz spectrum and that paid by MTS in 2013 to bring it at par with the other spectrum held by all operators. Only then will DoT reshuffle the blocks and make it contiguous so that Jio or another operator can use it for 4G.
@Esmail Bro: Do you think DOT would remove the guard between Jio’s and Airtel’s blocks for B5 in UP (West) to make their blocks contiguous so that they can deploy it as a single 10 mhz contiguous block ? As far as I know DOT is not obliged to do that just for the purpose of spectrum sharing since the blocks are held by 2 different operators. Am I correct or not ???
Yes they are not obligated to do that, but even if DoT doesn’t make it contiguous, Airtel and Jio can still sign a spectrum sharing pact and use it with intra band carrier aggregation B5-B5 to make a resultant 10 MHz block. And if Dot does make it contiguous through harmonization in the future then they can deploy it without the carrier aggregation as a single 10 MHz block.
@Esmail Bro: I doubt that Jio would use B5-B5 Intra-band carrier aggregation. Also there are limited devices in the market that support B5-B5 Intra-Band CA. They already have 15 mhz of Band 5 in Mumbai LSA. And as far as I know they have not deployed B5-B5 Intra-Band CA anywhere in Mumbai. Also did you find B5-B5 Intra-Band Carrier Aggregation on Jio anywhere in Mumbai ???
@Esmail Bro: Reply for this ?
I haven’t been actively monitoring that so I’m not sure whether they have deployed it here in Mumbai.
@esmail I was searching network manually. I saw Reliance 4G and also 4G. I think they are not same. If you agree then do RCOM still provide 4G or wireless service.
Yes Rcom 4G is still live in all circles where they have band 1 spectrum block of 5 MHz. They are still catering to some enterprise level customers and they still report subscriber figures to TRAI every month.
