Pan India Telecom Spectrum holding chart 2024
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,761 comments
Share article:
Follow us
Pan India Telecom Spectrum Portfolio 2024
Decimal values are rounded off to the nearest whole number for ease of representation.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Spectrum sharing is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of an operator acquiring the spectrum.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of an operator acquiring the spectrum.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1515)Forum replies (246)
Loading new replies...
Reply 4 likes
Reply 3 likes
1,761 thoughts on “Pan India Telecom Spectrum holding chart 2024”
  1. @esmail Do you agree that TDD based configuration should be adopted
    for 24.25 to 28.5 GHz frequency range? Kindly justify your
    response.
    Reply
    • All high-frequency bands will preferably adopt the TDD system only not FDD. This is because TDD systems can be flexible with the bandwidth allocation for uplink and downlink activity as per the user load and demand, which FDD cannot do since the uplink and downlink bandwidths are fixed and symmetrical.
Leave a Comment
