mm-Wave Band | 22000 | 17600 | 5350 | 0 |
Total | 26,800.8 | 22,138.1 | 8,030.4 | 1,086 |
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
@esmail where do you live and which operator you use ?
Mumbai circle, Jio for 4G on mobile and Airtel xstream for home broadband.
@esmail I used to keep eye on telecom operators FY results. I found that JIO profits are 3-3.5× of airtel but lacks in revenue compared to Airtel. JIO have more than 1.5 × BTS than Airtel. Also it’s arpu is lower than Airtel. Even though how they are making so much profit ? Is it because of their low operational cost or something else ?
Airtel has to maintain its legacy 2G network which requires additional capex and those subscribers dont generate that much revenue which is why Airtel keeps deactivating them to prevent dilution of arpu. Jio only needs to maintain single 4G network and it has all the heavy data users which bring in good revenue but even that inactive user base of Jio was diluting its arpu so now Jio has also started to deactivate inactive numbers in bulk.
Is it also because traditional operators have to maintain both switcing center and routers ?
Yes
Is there any role of optical fiber for operational cost ?
The right of way for laying the fiber is costly not the fiber itself.
You mean underground deployment is costlier than overhead. Does even in Mumbai they lay the disgusting looking overhead fiber cables ?
