Pan India Telecom Spectrum holding chart 2024
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,714 comments
Share article:
Follow us
Pan India Telecom Spectrum Portfolio 2024
Decimal values are rounded off to the nearest whole number for ease of representation.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1488)Forum replies (226)
Loading new replies...
Reply 4 Likes
Reply 3 Likes
1,714 thoughts on “Pan India Telecom Spectrum holding chart 2024”
  1. @esmail what if we start paying Rs 50 per GB and also the data usage remain same considering the constraints that our UE doesn’t support carrier aggregation and mimo. Just a simple LTE set. Will we get better speeds than before ? Somewhat like Airtel platinum 4G ?
    Reply
    • If data tariff increases then definately the usage will reduce and the overall speeds will improve even if you have a handset which doesn’t support CA and MIMO.
    • DoT is the government body which actually owns the spectrum which it leases out to the telecom operators for a fixed number of years and earns from that. They are the sole decision making authority with respect to telecom operations.
      TRAI is a body that reports to the DoT and regulates the tariffs of the telecom and broadcasting sectors. DoT consults TRAI and asks it to give recommendations about issues like spectrum floor prices for the auction, etc. But the final decision even in that regard lies in the hand of Dot. TRAI can only recommend, whether or not to implement it is in the domain of DoT.
      As of now the Indian Telegraph act of 1885 gives absolute and unrestricted control to DoT to take any decision it wants and the operators have to just comply with it, they don’t really have a say in the matter. But this will change in the next 2 months, hopefully we will have a new telecom act which will include digital services in it and will rationalise the power that DoT currently enjoys.
    • Dot is shit. Because your these old minded beaurcrates Indian telecom industry is suffering.
Leave a Comment
