@esmail Do you agree with TRAI “fastest network / voice quality report ” ? I have seen them saying JIO as fastest operator and BSNL as best voice quality Operator.
The TRAI report is based on peak performance by all operators in the most ideal conditions in a month it does not take an average of performance based on multiple readings in real life usage scenarios at congestion peak hours like Open signal report does. So it’s all about the test methodology used by an agency which gives the difference in reports. I would personally recommend going by Open signal report to get the true picture.
Oo i see the same you say in a article today.
So can we say it is fake or baised to JIO because since its launch trai is the b**tlicker of jio.
@esmail why in spectrum chart vi is having 30Mhz of spectrum in Gujarat And Maharashtra Circle ? Is it a single block
I take it that you are referring to Vi’s holding in band 41 for this question. The spectrum in this band was auctioned in block sizes of 10 MHz each in the 2016 auction. The chart just shows the total holding by an operator in a band in a particular circle and not the number of blocks. Since all the spectrum was bought together in the same auction it is shown as 30 MHz in the same red colour. But if Vi is to deploy it for 4G, it can do so only through carrier aggregation using a 20 MHz and a 10 MHz chunk.
Hey @esmail, on a related topic is it possible for DoT to put the remaining spectrum (140 MHz+ per circle) on auction next year for 5G rollout?
A lot of things are possible, the government can decide to do whatever it deems in the best interest of the country so can’t predict anything in that regard.
