@esmail why in general we get much lower upload speeds than downloads ? Even in FDD LTE
Hi,
Is the quantum of the spectrum mentioned is confirmed for the 2022 auction in 600, 2500 and mm waves?
As of today that is the status as I have mentioned in the article. It may change by the time of the auction if more quantum becomes available by then.
