@esmail is it possible that bsnl can launch 4G also on b8 5Mhz block and on remaining spectrum 2G ?
Majority of BSNL user base is comprised of 2G subscribers, BSNL wouldn’t risk deterioration of service quality on 2G for strengthening it’s 4G network so I don’t see that happening since it has limited holding in 900 MHz band.
@esmail what if the operator has a 20Mhz block and one 10Mhz block | a 20Mhz block and two non contingeous 10Mhz of block ? To which block a non CA phone connect ?
It will connect to the 20 MHz block since it has higher available bandwidth.
There are two things called cellreselectionpriority & idle cellreselectionpriority. These are priority values set in the LTE signalling. If both are same, then UE latches to higher bandwidth carrier (only if signal strength is below a set threshold i.e., better than -115 dB in most cases). Usually operators assign higher priority to higher bandwidth carriers but it is possible sometimes they would want to put you on a lower bandwidth carrier
