Hey Esmail, any idea when the auctions will be held? It’s already September, and the third quarter is ending, and still no auctions in sight.
Ya it seems the government is waiting for the outcome of the spectrum ownership case that supreme court passed on to NCLAT to give the ruling about. Once they know what’s happening with that spectrum they will know how much they can put up for sale. So if the auction doesn’t happen in the last quarter of 2020 then it will probably happen in Q1 2021.
Esmail :
> Is there any possibility of BSNL making 3G video calls a part of voice calling (that is voice call tariffs will apply for 3G video calls also)?.
I mean if a user has enabled UL calling pack or Rs.0.30 / Rs.0.01 for 2 second pack in BSNL, the 3G video call rate must also be the same
> Why didn’t the operators make the 3G video call rate same as voice call (Rs.0.025 per second or unlimited if pack is enabled) even after introducing the unlimited voice calling packs?
> What is the difference between a normal 3G video call and a 4G video call (not via any app)?
> What is the difference between the voice calls made on 3G network along with data usage and the same (voive call + data usage) done on a 4G VoLTE network?
> How come 2.75 G network like RGSM allowed simultaneous voice calls and data usage?. This was started only from 3G. Right?.
Native video calling is a failed concept, it was envisioned to allow direct video calling from the phone’s dialer without the need for a 3rd party aap, but since all operating systems work on different mechanisms this couldn’t be achieved in a smooth fashion and thus never took off. It’s best to use video calling through an app like skype, duo, WhatsApp etc which provide a common platform on any os and make the calls possible.
I didn’t ask whether 3G is a success or not. I asked how the voice and data are handled simultaneously in 3G and 4G.
As far as the data component is concerned, both 3G and 4G transmit it as packets. For the voice component, 3G carries voice exclusively on a circuit switching framework whereas in 4G the operator may either choose to fall back the voice onto the circuit switching framework (CSFB) of the 3G or 2G network it already has or it may choose to use Voice over LTE (VoLTE) where the voice is also transmitted as packets on the same data network without needing to establish a dedicated circuit interconnection.
In both the scenarios data as well as voice can be transmitted simultaneously.
Then how did voice and 2G EDGE data worked at the same time in RGSM numbers during 2009?.
