@esmail does JIO has 5Mhz spectrum in band 5 in j&k , NE and Assam because it is sufficient there or some constraints bcz only 12.5 MHz of spectrum is available there. other places they have 10Mhz spectrum.
Coz the other 5 MHz chunk is with Rcom and if Jio wants they can add the remaining 2.5 MHz but that won’t be of any use to them coz it will make the holding as 7.5 MHz not 10 MHz which Jio would want for LTE deployment.
@esmail has band 8 and band 3 taken for granted to serve 2G service ? And band 8 and 1 for 3G ?
