How much spectrum has been deployed by Jio in 1800 frequency (B3) in Andhra pradesh and Telangana ? Did they upgrade B3 spectrum in AP or not ?
All 3 bands fully deployed
Jio has deployed addittional band 3 – 5 mhz won in march auction across karnataka circle.
It was already deployed since months.
No it was deployed on 27th September only.
How much is deployed by Jio in 1800 band (B3) in AP & telangana ?
10MHz deployed in AP month ago
Wanted to mentioned the same on other forum.
