Total | 26,800.8 | 22,538.1 | 8,030.4 | 1,086 |
Jio deployed B5 10Mhz in TN today
https://i.postimg.cc/fLM1mWhb/IMG-20210928-185243.jpg
And how much is deployed in B3 in Tamil Nadu (Not Chennai) ?
In RoTN jio has 10mhz B3
And what about Chennai B3 ? Have they deployed 10 Mhz B3 on all sites in Chennai with full PRBs ?
@esmail How will airtel use 4.6Mhz of spectrum in B8 ? This isn’t a complate block
