Mid Band | 1470.8 | 1964.9 | 1531.6 | 850 |
Total | 26,800.8 | 22,538.1 | 8,030.4 | 1,906 |
@esmail does jioprivate net wifi uses same 2.4/5 GHz band as other devices do ? If yes then How their coverage is greater ? Is wimax and air fiber same ?
Yes it uses the same two bands which is why ur phone can see the signal, your phone also supports only these two bands for wifi. Coverage will be better since they have stronger routers with better antennas. Air fiber also uses the same unlicensed spectrum as wifi, but it’s different in a way that it’s not a public wifi, it’s a direct link between the operators and subscribers after checking the direct line of view between the operators antenna and the subscribers home which is fitted with the receiver.
@esmail What does company mean by saying “we are upgrading our site” other than any change in the bandwidth of spectrum ?
Can mean many things, new antennas getting added, microwave backhaul being replaced by fiber backhaul, MIMO or carrier aggregation being enabled, new bands getting enabled. You can ask the network engineer who is working on the site for the exact specifics.
