Mid Band | 1470.8 | 1964.9 | 1531.6 | 850 |
Total | 26,800.8 | 22,538.1 | 8,030.4 | 1,906 |
@Esmail Does wireless broadband speed depends on spectrum bandwidth ? Does no. of gsm antennas effect speeds ? Will there be any difference in speeds if a additional site is established near existing one ?
Yes, higher spectrum bandwidth gives higher speeds. Number of antennas will have a difference if the tower and your phone both support MIMO. If an additional tower is set up next to an existing one then it will help in reducing the congestion on the single tower by having half the users shift to it. This will reduce the bandwidth contention ratio and ultimately provide better speeds to each user.
Jio has deployed 10 mhz in 850 frequency band in Kolkata circle.
