Jio has deployed 10 Mhz in 850 frequency band in West Bengal circle.
Bro you watch updates on his channel and in turn tag him again for doubts lol
No additional deployment so far in west bengal. I recently check, shows 5MHz 850 band at my location.
@Esmail bro: Why was 900 band more expensive than 850 band in MP & CG circle in recent auctions. Ideally 850 band should be more expensive than 900 band (as is the case with other circles). Also Band 5 is of lower frequency than Band 8, so why did DOT kept base price of Band 8 higher than Band 5 in MP & CG in recent auctions ?
Well DoT gets the base price recommendations from TRAI which has its own complex pricing calculation strategy. So only TRAI can answer that question of yours. It sure was against common logic comprehension.
