@esmail why JIO towers in urban areas don’t have circular shaped antenna ?
That is meant for microwave backhaul and jio towers in urban areas have fiber backhaul so they dont need the circular shaped antennas.
Can anybody Confirm that “Had JIO deployed their new additional 5MHZ of spectrum in B5 and B3 on the sites in Bihar circle ?” If yes then please attach the screeshot.
Yes already done long ago.
