Pan India Telecom Spectrum holding chart 2024
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,721 comments
Share article:
Follow us
Pan India Telecom Spectrum Portfolio 2024
Decimal values are rounded off to the nearest whole number for ease of representation.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1495)Forum replies (226)
Loading new replies...
Reply 4 Likes
Reply 3 Likes
1,721 thoughts on “Pan India Telecom Spectrum holding chart 2024”
  1. Esmail ji,
    Can you confirm that balance 1.2 mhz in 900 mhz allotted to Airtel in Gujarat or not.
    It was to allocation from BSNL on 01.09.2021
    Reply
Leave a Comment
