mm-Wave Band | 22000 | 17600 | 5350 | 0 |
Total | 26,800.8 | 22,138.1 | 8,030.4 | 1,086 |
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
@esmail if the fdd spectrum have same bandwidth for uplink and downlink then will upload and download speed aren’t symmetrical ? For example in BSNL 3G I get above 500kB/s but upload sucks.
@esmail How can I improve my telecommunications knowledge like about spectrum , BTS , sector antenna , their radiation pattern and orientation etc. for free. Is there any platform for this ?
Not that I’m aware of any one site, you will have to search on Google only.
