@Esmail make Indian specific chart for wifi spectrum specially for 60ghz band. Which will be more important for broadband industry.
As of now only 2.4 GHz and 5 GHz spectrum is unlicensed for use of WiFi. 60 GHz spectrum or V band is not unlicensed in India and hence WiGig services are not commercially available and the COAI is heavily lobbying against it so it looks unlikely it will ever be launched.
@esmail spectrum sheet not working
It’s working fine at our end, try loading it in incognito mode in your browser.
