mm-Wave Band | 22000 | 17600 | 5350 | 0 |
Total | 26,800.8 | 22,138.1 | 8,030.4 | 1,086 |
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
Despite largest Sub Band, Why indoor coverage of jio is very weak with compare to Airtel?
Here in Up East Jio indoor network is the strongest among all the telco
But jio speed is low as compared to airtel in most of the part UP east
Hey Suman, the primary LTE band for Jio is B40, which is not quite ideal for decent indoor coverage, especially in high density areas. I’d suggest you to manually select B3 and B5 if you have a rooted Android phone. If you have a Samsung phone you can simply download Samsung Band Selector app from PlayStore and select the bands manually. I know it can be a pain sometimes but this is the only workaround.
What is the spectrum & Tower deal between Jio and Rcom?
Spectrum sharing deal is live between the two operators in Assam and North East circles. The tower and fiber deal is approved and will be closed soon.
