@esmail VIL B3 in TN is reduced as much as 8Mhz ???
11.4 MHz liberalised and 1 MHz non liberalised as per latest quarterly report of VIL.
But how they surrendered ?
They might have been breaching the spectrum cap for TN circle post-merger so might have had to surrender the excess spectrum from the administratively allotted one in band 3.
@esmail according to your knowledge who may buy out Aircel and rcom spectrum ?
As of now it belongs to UVARCL and they will invite bids from the existing operators. Only Jio and Airtel are in a position to buy it selectively. I belive the non liberalised part of Aircel spectrum won’t find any takers as it will need the buyer to pay for getting it liberalised at market rate. Moreover the 2100 MHz spectrum will attract most interest by Jio since it is available in 5 MHz contiguous chunks and has a ready ecosystem for 4G devices supporting it. The 10 Mhz of band 3 spectrum of Aircel in Tamilnadu circle will also find takers. 900 MHz spectrum of Rcom might interest Airtel.
I feel even Vodafone Idea should sell off some of its spectrum to Jio and Airtel as they have surplus spectrum and a high fee to pay for AGR dues and the subscriber base is on a constant decline.
@esmail but if jio buys B1 from Aircel it again needs to invest in antennas, radios to deploy it. On the other hand Airtel already has B1 radios pan India. What’s your thoughts on it ? Also will jio buy B28 ?
And for VIL I guess most of the Vodafone spectrum are expiring which they will not bid & renew which in turn automatically goes to other operators.
Yes, I believe Jio might go for 20 MHz pan India in band 28 for the superior coverage. Band 1 it may consider for capacity. Investment in radios is a long term gain, coz the same can be reprogrammed for 5G use as well with just a software tweak.
