Which LED TV is best suitable for me ?
  • Thread starter Thread starter Karthik
  • Replies Replies: Replies 32
  • Views Views: Views 6,053
nskaran said:
tech genie bro, for good PQ what is the minimum requirement of refresh rate & screen resoulution are required. can you give us how to find out the refresh rate & resolution when purchasing led tv.
Here you go (for 32" LED):
Refresh rates (for India): 100 Hz or better (Please note that this is the backlight scanning rate called "Clear Motion Rate," "TruMotion," "Motionflow XR," and so on)
Resolution (for DTH SD channels / Cable): 1366 x 768 (known as HD TV)
(for DTH HD channels): 1920 x 1080 (known as Full HD TV)
You can go through the website and check the specifications for the make & model.
For details please refer to :
TV Buying Guide - Choose the right TV for yourself
:tup
well you can buy Toshiba, Sansui in your budget samsung, LG and Sony would be costly. even i had the same budget and got myself sansui LED TV I like the PQ on d2h showed by the dealer, even it had stunning PQ with TS and Dishtv tru HD.
I am planning to buy a new Led TV 32 inch. My maximum budget is 35k. Can ANYONE please suggest me the best tv..
Why 32 Inches. What is your viewing distance? what about smart features.
Full HD 1080P or 720P if you go for 32"
Hi Umesh, please see the Distance Vs Size table here:
My choices are:
1) Samsung F4000 USB Movie HD LED TV (MRP Rs. 32,100) - well within budget :tup
Screen Size: 32 Inches
Type of Television: LED
Resolution: 1920 x 1080 Pixels
Clear Motion Rate: 100Hz
Sound: 10 watts x 2
HDMI Input
1) Samsung UA32EH6030R (MRP Rs. 38,900) - awesome TV just over-budget but can get for less (Rs. 32,900); check link:
Samsung UA32EH6030R Online Price in India, Specifications, Reviews, Features : Televisions - Compare India
:luv
3D Ready
Clear Motion Rate: 200Hz
Sound: 10 watts x 2
HDMI Input
My choices are:
Sound: 10 watts x 2
HDMI Input
1) Samsung UA32EH6030R (MRP Rs. 38,900) - awesome TV.
:luv
3D Ready
Sound: 10 watts x 2
HDMI Input
Thanks for the information buddy and the second option that you have mentioned above would be a good Led tv.. Samsung UA32EH6030R (MRP Rs. 38,900) - awesome TV just over-budget but can get for less (Rs. 32,900); check link:
In Reliance digital it is for rs 34,900..
