Seeking Help Port speed in BSNL Broadband 1199/- plan
  • Thread starter Thread starter Real AB
  • Replies Replies: Replies 30
  • Views Views: Views 6,663
How to mate?
which modem/router?
In D-Link
Status- ADSL Driver
SNR Margin should be high and Attenuation should be low for a good and stable connection
if u live near ur exchange SNR will be around 30-40. Its a highly stable connection
which modem/router?
In D-Link
Status- ADSL Driver
Here you have it mate:
Bro your line is not good. SNR is low & attenuation is high. It is not possible for you to get a higher port speed. They have keep it low so that your connection will remain stable. How far is the telephone exchange from your home? (it looks like it is more than 3km.)
Between 2.5-3 kms. So no chance of better speed then?
Mostly, No.
But do one thing. Go to advanced settings > ADSL/DSL Settings > Uncheck all except G.dmt (Only G.dmt should be ticked) > Apply/save. Let internet connect again & post the above stats screenshot again.
Mostly, No.
You mean here? Untick all including those under Capabilities?
there's noise in ur line. that's why SNR Margin is low.
Sound to Noise Ratio.
Line may be rusted or may be dipped in water.
or loose connections all will lead to low SNR. Low SNR will lead to frequent disconnection of the line.
As PRK bro told keep GDMT/ADSL2+/G992.5/G992.1
is this router imported.? its shown T1.413 in ur router. its an american standard.
