Tata Sky Broadband 1 Gbps Plan Installation and Review
  • Thread starter Thread starter d5aqoep
  • Replies Replies: Replies 18
  • Views Views: Views 16,102
How's it performing for you?
Great actually. No OTT fluff and they even let me use my own ONU. Upload speeds are restricted to 600 Mbps on OLT. But I can do with that as long as I am hitting almost 2Gbps on download.
Hitting 2Gbps download speeds, are u using your modified setup for achieving? Man which plan u are using and what are the pricing kindly share :censored::love:
29k for 1gbps for 1 year. I use basic VSOL V2802RH 2.5G ONU which feeds into Ubiquiti UXG-MAX which also has 2.5G WAN and LAN ports.
I have used that Ubiquiti router, if my memory serves me right it has a Usb c cable and performance is top notch. Good plans for 1gbps I see.
It's not Tata Sky Broadband. It is Tata Play Fiber.
At least check the thread creation date/year. It's a thread from the year 2021, Tata Play Fiber was known as Tata Sky Broadband back then. Only later in the year 2022 it was rebranded (reference).
Even the first post has pictures with references with Tata Sky Broadband branding yet you are saying this!
@d5aqoep what kind of speeds do you get in other places, like downloading off other non-local non-nearby places?
I do hit around 1.6 -1.8 Gbps on most sites while downloading. Eg Linux iso or Windows iso straight from official sites. I I haven’t tried torrenting but since Microscan also provides static IPv4 for 199+ GST per month, I don’t see a problem with torrents either.
This Ubiquiti UXG-MAX was only released in May 2024 and it’s one of their best routers. Wondering why you changed it so soon? Unless you are talking of their earlier products.
