need urgent help
  • Thread starter Thread starter divakar_mba
  • Replies Replies: Replies 25
  • Views Views: Views 4,161
once you convert definitly you will lost quality.are you using any writing software or directly copied to cd.or?
if you copied directly ,player cant understand the format directly.so using blurau disc creating software for write it will take care of remaining.
just suggestion i not tried earlier.madhan brother will help you.
divakar_mba said:
i copied to my external hdd
so file cant understandable by player.try with writting sw to make a bluray disc.it will playable i think.
try with some low price disc for testing.
If you have a laptop with a HDMI Out port,play the movie on your computer and display it to the TV
i had converted the file to mkv but audio is not coming hindi,some other language coming.but original file having multiple audios. how to get hindi
