need urgent help
  • Thread starter Thread starter divakar_mba
  • Replies Replies: Replies 25
  • Views Views: Views 4,167
Try Any Audio video Editor Software , Example "Pinnacle Studio" Is best For Converting Audio,video
divakar_mba said:
plz tell me how to convert multiple language audio video file
During conversion from Blu-ray to other format, the conversion software gives you an option to select desired audio track.
Here is one such converter
AVS Video Converter: perfect for home video conversion. Convert video fast & easily!
This software is having audio selection option during conversion.
Also you can limit the file size too.
I have not tried it myself, but sharing it here so that you can check it out & tell us.
divakar_mba said:
i had converted my 40gb 3 id*ots movie, quality was drastically down and new file is only 8gb.is there any other way to get full quality
Quality is only downgraded when it is converted with low bit-rate as compare to Original file, But quality never ever become low until & unless you keep the bit-rate in high proifile.There are some very nice converter on the web,You have to search it.
Blue-ray is not with every one yet and so don't expect much Answer from Blue-ray users, Neither me have and I can only tell you that a Video file having even Bit-rate of 1280 x 720,1360 x 768,1600 x 900 and at the moment above all which we see in full HD:1920 x 1080 can be played on 32inch & 40inch Led-tv's nicely. So you can't say that quality is low by converting.It depends upon the user how heavy file he/she wants according to the space he have.
So there are many Good CODEC'S used to FORMAT various Audio/Video files, The popular are XVID/DIVX/MKV/WMV/ etc. But again it depends upon you to have how much quality ? :)
As Bit-rate Increases the quality while converting it with same rate & it also increase and the size of the file ok. Now what happen in your case is Video may be fine the problem with your Audio format making you un satisfied,Because you want all languages as in Original file and that is again a professional job dear,Don't think that the Converter will do all the work in one go....For this one must have some knowledge of CODEC'S and the best Ready made PROFILES of converting these files.
HOW SIZE OF FILE INCREASES:-
Suppose you have FIVE languages and want that all languages on BLUE-RAY disk and what happen is ,"The SOFTWARE used in conversion again say do good job and make us the file with the required Audio formats.Now keep in mind unless we format the BLUE-RAY disk with the same format having all FIVE Audio track on that disk containing five languages.Why disk has 20GB or 32GB data because of all Audio five TRACK'S for particular language. ok :)
PL NOTE: While converting it from higher Bit-rate to some what lower the quality never decreases,Only quality which is some what downgraded is from lower Bit-rate to higher ones.means UP SCALLING.
@jenius-jatt Mostly audio file is smaller in size than video file.
For a three hour movie audio size should have been upto 2 GB per language, I guess.
So 5 tracks of different language audio file can take almost about 10-12 GB.
So if you have only one audio track after conversion, file size will be reduced by almost 8 GB or so, if video is intact in quality.
Yes but i had put a Example according to its file size as we don't have Experience of BLUE-RAY Audio/Video file am I right bro.
Yes I had converted some file of Audio.Video with XVID FORMAT from Original DVD without loosing any quality and fit 2/3 Movies in one blank DVD, Up to now I have been successful in converting six movies in one DVD with Good quality of Video.
The main Funda is you can decrease the Audio Bit-Rate to 64KB to 96kb and 128KB which is good for hearing Normal sound to some extent.
I also make a marriage 3DVD to One DVD with compression without missing any thing & quality is nice..:lol
Try this bro....
DVR Converter is your video converter for all your digital video recordings, compatible with DVD Recorders, Receiver, Digital Cameras, Hard-disk Recorders, DVD-S and DVB-T Streams, PC Tuner cards – both PAL and HD resolutions.
This utility converts videos in the following formats: mpeg/ mpg, ts, mod, tod, vro, dvr, pvr, mts, m2ts, tp0 and trp to WMV, DivX/ Xvid/ HDX4/ MPEG4 (.avi or .mp4), h.264 or MPEG2 compatible video streams. This leads to a high compatibility of your digital video recordings and you can process the newly created files with almost any other program or play them on a huge number of hardware players.
http://www.giveawayoftheday.com/dvr-converter-3-0/
