• Welcome to OnlyTech community forums. If you are an existing member of our DreamDTH forums, please use the same login credentials to login here. Create a new account only if you are not registered at DreamDTH before. If you have trouble logging in, please let us know through the contact form.
Difference Between GSM and CDMA
Dinesh jain
Guru
3 Feb 2014
GSM (Global System for Mobile Communication)
and CDMA (Code Division Multiple Access) are
two dominant technologies for mobile
communication.
1.Technology
The CDMA is based on spread spectrum
technology which makes the optimal use of
available bandwidth. It allows each user to
transmit over the entire frequency spectrum all
the time. On the other hand GSM operates on
the wedge spectrum called a carrier. This carrier
is divided into a number of time slots and each
user is assigned a different time slot so that until
the ongoing call is finished, no other subscriber
can have access to this. GSM uses both Time
Division Multiple Access (TDMA) and Frequency
Division Multiple Access (FDMA) for user and
cell separation. TDMA provides multiuser access
by chopping up the channel into different time
slices and FDMA provides multiuser access by
separating the used frequencies.
[size=medium]
2.Security
More security is provided in CDMA technology as
compared with the GSM technology as
encryption is inbuilt in the CDMA. A unique code
is provided to every user and all the
conversation between two users are encoded
ensuring a greater level of security for CDMA
users. The signal cannot be detected easily in
CDMA as compared to the signals of GSM, which
are concentrated in the narrow bandwidth.
Therefore, the CDMA phone calls are more
secure than the GSM calls. In terms of
encryption the GSM technology has to be
upgraded so as to make it operate more
securely.
3. Spectrum Frequencies
The CDMA network operates in the frequency
spectrum of CDMA 850 MHz and 1900 MHz while
the GSM network operates in the frequency
spectrum of GSM 850 MHz and 1900 MHz.
4. Global Reach
GSM is in use over 80% of the world’s mobile
networks in over 210 countries as compared to
CDMA. CDMA is almost exclusively used in
United States and some parts of Canada and
Japan. As the European Union permissions GSM
use, so CDMA is not supported in Europe. In
North America, especially in rural areas, more
coverage is offered by CDMA as compared to
GSM. As GSM is an international standard, so it’s
better to use GSM in international roaming. GSM
is in use by 76% of users as compared to CDMA
which is in use by 24% users.
5. Data Transfer Rate
CDMA has faster data rate as compared to GSM
as EVDO data transfer technology is used in
CDMA which offers a maximum download speed
of 2 mbps. EVDO ready mobile phones are
required to use this technology. GSM uses EDGE
data transfer technology that has a maximum
download speed of 384 kbps which is slower as
compared to CDMA. For browsing the web, to
watch videos and to download music, CDMA is
better choice as compared to GSM. So CDMA is
known to cover more area with fewer towers.
6. . Radiation Exposure
GSM phones emit continuous wave pulses, so
there is a large need to reduce the exposures to
electromagnetic fields focused on cell phones
with “continuous wave pulses”. On the other
hand CDMA cell phones do not produce these
pulses. GSM phones emit about 28 times more
radiation on average as compared to CDMA
phones. Moreover, GSM phones are more
biologically reactive as compared to CDMA.
[/size]
Difference Between GSM and CDMA | GSM vs CDMA
Sarkar
Guru
1 Jun 2013
Is 3G(HSPA can be as fast as 42 Mbps at least in theory where as CDMA's max speed is 3.6 Mbps) not GSM ? Why is the article only compairing with EDGE network ? Someone plz clarify it
And GSM also works on 900 MHz and 1800 MHz but article doesn't mentioned it
OP
D
Dinesh jain
Guru
3 Feb 2014
already mentioned @ point no.3
sam
Guru
19 Aug 2014
WCDMA is a New Technology
as GSM & CDMA are 2g technology (900/1800)
WCDMA is 3G with 2100 frequency...
Sarkar
Guru
1 Jun 2013
syam said:
GCDMA is a New Technology
GCDMA is 3G with 2100 frequency...
I know WCDMA which is 3G in GSM but What is GCDMA ?:huh
As far as I know HSPA(also called 3.5G) is GSM.
sam
Guru
19 Aug 2014
its is mistake bro....
Yes its W not G
Thread starter Similar threads Forum Replies Date
Optimus_Prime Discussion Difference between Genuine OS and Cracked OS Computer OS & Software 2
A Seeking Help What difference between fibre and cable or any other broadband (physicaly) Broadband Providers 9
A Seeking Help Difference between 48 inch led tv vs 50 inch? TV & Audio/Video devices 23
Gobinaath Seeking Help Difference between voltage protector & stabilizer ?? Consumer Electronics 18
Raviteja Seeking Help What's the difference between Ubuntu and Unix OS Computers & Hardware 8
D Difference between jio smart phone sim and jiofi sim Telecom Services 4
F Whatz the difference between 720p and 1080i. TV & Audio/Video devices 9
R Difference between G, E, 3G, H, H+ and 4G symbols Telecom Services 19
S 48 Percent of Indians See No Difference Between 2G and 3G Internet Telecom Services 61
T No ‘emotional difference’ between 2D and 3D Mobiles & Accessories 0
D Difference between Samsung S3 Made in India, china and Vietnam Mobiles & Accessories 2
K what is difference between 3g and wcdma Mobiles & Accessories 2
S Difference Between C & C++ Computers & Hardware 3
Gobinaath OTF Exclusive Reliance JioPhone Vs Airtel Celkon Smart 4G: Every difference that you wanted to know Mobiles & Accessories 8
Gobinaath Big difference in salaries of men and women's Indian cricket team .. Cricket 6
R Mini-IPL in America put on hold, Anurag Thakur blames time difference: Report Cricket 1
Bapun Raz Feeling the difference, literally! General Topics 0
OnlyTech.com Article TRAI makes interconnection between two PSTN and NLD network OnlyTech Articles Discussions 0
OnlyTech.com Article Allow leasing of spectrum between two licensees: Reliance Jio OnlyTech Articles Discussions 0
Lurie Seeking Help Suggest me a touchscreen 360 degree hinge laptop between 30-50k Computers & Hardware 4
S Seeking Help Suggest Samsung Mobile phone in between 12k to 14k Buying Guidance 0
Bapun Raz Barrier - Share your keyboard and mouse between computers Apps & Websites 0
Sparker0i Seeking Help Need to decide between Jio Fiber and RailTel Reliance Jio Fiber 19
H Seeking Help Suggest me phone between 10-12K! Mobiles & Accessories 3
Optimus_Prime OTF Exclusive Announced plan comparison between Telecom operators Telecom Services 85
Similar threads
