Seeking Help Difference between 48 inch led tv vs 50 inch?
  • Thread starter Thread starter ato_tho
  • Replies Replies: Replies 23
  • Views Views: Views 8,258
Samsung Joy Plus 42 inches which starts troubling even after 3 months.
Myself i have never used a samsung tv but have been hearing bad stuff about it from many people so i guess better to stick with sony hey.
Go with 50" @ato_tho ... me too confused while buying 40" or 42" ?
50 is my first choice but i really like one thats 48 inches and everyone's been telling me you cant tell the difference between 48 and 50. Also i checked both the tv's and i feel 48 had better looks and pq is better too than 50 inches one so i'm leaning towards that right now.
Since you are using 50” currently, I think you should upgrade to a bigger screen, go for Sony 55”.
You will definitely observe the difference even 2 inches small.because it is not just comparison,its daily view,so your eyes already got some illusion about your 50 inch TV size and Viewing.so small size makes difference.
better go with same or bigger,not smaller.
