Seeking Help Confused between S22 and S23 FE
Shivpatel
16 Jul 2019
Hello,
I want to buy new smartphone for my Dad but I am little bit confused between S22 vs S23 FE…
Any expert pls suggest for review…
None of them are good phones. S22 has severe battery backup and heating issues. Meanwhile, S23 FE is simply a bad value. The correct price should be 30k. It will drop to that price very soon. Better to go for S21 FE instead of S23 FE and save some money.
The best decision would be getting the S23. It's often available cheaper than S23 FE.
S21 & S22 - 2022 model
S23 - Oct 2023 model
S21 Android 11
S22 Android 12
S23 Android 13
All Functions are same.
S 21 is best in the above comparison.
S22 had reverse charge and S23 don't had
S21 Android 11
S22 Android 12
S23 Android 13
Please correctly mention the device names, if you are talking about the FE series or the normal S21/S22/S23 series. Because I was using S21 Ultra till January 2024 and it already received the Android 13 update by then. The S21 series was launched on 2021, not 2022.
