Problem in Blind scan
  • Thread starter Thread starter Johny
  • Replies Replies: Replies 1
  • Views Views: Views 798
Johny
1 Sep 2011
Friends,
I am facing a problem while Blind scan in my receiver Technosat. I have 4 cable connections, port 1 Is-17, port 2 - 10e/9e, port : 3 - 7deg 4, port 4 - 13e.
I tried with a 4 port diseq switch and a 6 port diseq, while scanning it will start with the same satellite channels and in the middle is-17 channels will come, and after that it will complete the balance channels of the initial satellite.
For eg; if I am using blind scan for 10/9e, it will show start with 5-6 channels of 10deg e, then 123 channels of 1s-17 and finally the balance channels of 10/9e.
This is happening for other sats also. All the cases is-17 channels are coming in between.
Is it a problem of diseq switch or the receiver ? I tried with 2 switches . Same impact. this is happening while blind scan only.
I observed the same problem yesterday. I scanned Asiasat blindscan but saw it is scanning NSS 6 also. Both are connected through monoblock. I am using DiSEqC 1.1. One port for monoblock and another for ST2. I am not seeing ST2 TPs but only the sats from monoblock.
