Asus Zenfone 3 and Zenfone 3 Deluxe smartphones have surfaced in leaked renders. Both the smartphones were listed on design site Red Dot 21.
The Zenfone 3 will feature a 2.5D glass on both the front and back of the handset and will have a thin aluminum design. As per the renders, the phone has a square rear camera module at the back with a dual tone LED flash and a laser auto focus. It is expected that it would come with a biometric scanner. Moving on to the front side, there are the usual set of three capacitive function keys below the display.
Other specifications are not mentioned, but both the phones will support USB Type C, a front facing flash and an optional “Smart Flip Cover”. Moving on to the Zenfone 3 Deluxe, it also sports a metal design and features a physical home button below the display with two capacitive buttons on either sides. The physical button could be backed with a fingerprint sensor. A power button is also seen on the right side of the phone.
The Asus Zenfone 3 is shown in Gold, Silver and Black color variants. It is expected that Asus will announced the Zenfone 3 at Computex 2016 at the end of May and beginning of June.
Asus Zenfone 3 and Zenfone 3 Deluxe renders and specs leak
