Seeking Help Which is Better Mobile Phone: Vivo v11 Pro or Oppo F9 Pro?
  • Thread starter Thread starter DTH Fan
  • Replies Replies: Replies 20
  • Views Views: Views 2,935
I would recommend holding a few months off. Nokia 8.1 launch is around the corner, and looking at the China variant, the selfie cameras are at par with the f9 pro
If waiting is an option, nokia x7 (7.1 plus) can also be considered.
For Oppo F9 Pro, @Dinesh jain bro may help you as he recently purchased it.
I'll suggest you to wait for few weeks as Realme is going to launch Realme3/pro which will have Helio P70 & obviously there camera will be good with depth effect for background blur.
My wife doesn't like notch display but Oppo/Vivo waterdrop notch looks decent.
Can you guys tell me which one is better among both specially camera with background blur effect.
I would recommend you to wait for a while Oppo F9PRO & Vivo V11 PRO is old thing now!!!
And, yes they won't support portrait mode and I think they support bokeh mode which is similar to that but won't perform in most cases.
Oppo & Vivo handset are not that tough.
