Sony just launched the Xperia XA Ultra smartphone in India as it had promised last week. It was announced in May, has a 21.5-megapixel rear camera with LED flash, Hybrid Auto-Focus and a 16-megapixel front-facing camera that also has a LED flash and OIS (Optical Image Stabilization) for capturing shake-free selfies. It also has a dedicated camera button.
Sony Xperia XA Ultra specifications
6-inch (1920 x 1080 pixels) display with Mobile BRAVIA engine 2
Octa-core (4 x 2.0 GHz + 4 x 1.0 GHz) MediaTek Helio P10 (MT6755) processor with 700MHz Mali T860MP2 GPU
3GB RAM, 16GB internal memory, expandable memory up to 200GB via microSD card
Android 6.0 (Marshmallow)
Dual SIM (Optional)
21.5MP Primary Camera with 1/2.4″ Exmos RS sensor, Hybrid Auto-Focus
16MP front-facing camera with flash, Sony Exmor R sensor, OIS, 88-degree wide-angle lens
Dimensions: 164.2 x 79.4 x 8.4mm; Weight: 190g
4G LTE, WiFi 820.11 a/b/g/n , Bluetooth 4.1, GPS, NFC
2700 mAh battery
The Sony Xperia XA Ultra comes in White, Graphite Black and Lime Gold colors and is priced at Rs. 29,990. It will be available through all Sony Center and major electronic stores across India.
Sony Xperia XA Ultra with 16MP front camera launched in India for Rs. 29990
Dual SIM (Optional)
2700 mAh battery
