Pakistani military building Android based ipads
  • Thread starter Thread starter kramkumar
  • Replies Replies: Replies 1
  • Views Views: Views 1,352
kramkumar
22 Mar 2011
The Pakistani military has been using spare manufacturing capacity to build an Android fondleslab to go up against Apple’s dominant tablet.
The tablets are built by the Pakistan Aeronautical Complex (PAC), one of the largest manufacturing facilities in the world, which primarily builds and tests aircraft for the Pakistani military. However, in conjunction with Hong Kong firm Innavtek, PAC is using spare capacity to produce a 7-inch fondleslab, as well as an e-book reader and a netbook.
"It's about using spare capacity. There are 24 hours in a day, do we waste them or use them to make something?" Sohail Kalim, PAC's sales director, told Associated Press. "The profits go to the welfare of the people here. There are lots of auditors. They don't let us do any hanky-panky here."
The PAC-PAD 1 is a fairly basic affair, running Android 2.3 on a 1GHz ARM processor, 256MB of RAM and available with between 2GB and 16GB of internal storage with space for a removable SD card as well. It’s WiFi only (802.11b/g) and designwise it’s not going to give Apple any significant problems, but the PAC-PAD does have the edge on price, costing around half of what a genuine Cupertino fondleslab would set you back.
PAC usually restrains its activities to assembling the JF-17 multirole fighter jet and J-8 jet trainer, designed by the Chinese, as well as making general aircraft parts for Boeing under contract and remote control aerial drones. The move into consumer electronics is unusual and so far only around 1,000 fondleslabs have come out of the facility, although a second generation PAC-PAD with 3G connections is promised by the summer.
http://www.theregister.co.uk/2012/02/20/pakistan_pacpad1/
