Need help for battery draining issue by camera app
  • Thread starter Thread starter karan
  • Replies Replies: Replies 15
  • Views Views: Views 1,694
I tried once
But it's automatically close AV & security apps too :(:(
It's not windows, so Why do you need AV to run in background in linux ? There is no autorun virus exists in linux which execute download file automatically without user interaction like they do in Windows. AV should run only on demand.
BTW there should hv an option for exclusion but I have not use it so cannot tell as MIUI does this for me
But bro if factory reset means data & installed apps are get erase
I think simple restart is enough imo isn't it bro ??
Gobinath bro i restart my phone many times already but it dont fix problem nd also sometime android system eats upto 20 percent battery
Moreever i disable all apps access for camera but still its eating battery....bro i dont want to loose my data do you think factory reset will help it?
Now i lost nealry 30% on internet usage before this issue it was only 13-15 %
