Seeking Help Need a printer suggestion
  • Thread starter Thread starter Optimus_Prime
  • Replies Replies: Replies 3
  • Views Views: Views 1,083
Status
Not open for further replies.
Optimus_Prime
5 Oct 2015
My sibling want to buy a printer tomorrow, so asking for suggestion here:
@mmadhankumar bro specially from you as you are expert in this field...but others suggestion also welcomed..
I want to be specific and to the point so that I can cover my needs
  1. Page Size- only A4 will be printed.
  2. Color or B&W - Mostly B&W, very rare occasionally Color
  3. Numbers of Page-average 20 Page per month, or sometimes no page at all.
  4. Connectivity- laptop/desktop not available. So Wi-Fi needed as printing will be done from Tab Only.
  5. Facility- Mostly will be use for Printing purpose but Scanner, Copier should there for future use.
  6. Budget- 8-12k
  1. Numbers of Page-average 20 Page per month, or sometimes no page at all.
  2. Connectivity- laptop/desktop not available. So Wi-Fi needed as printing will be done from Tab Only.
1. That's very less print per month. I strongly suggest ink tank printers for that kind of usage.
2. WiFi models are always costlier than the ones without wifi. If you want an cheaper option, consider connecting the printer to router (via usb or ethernet) and your tab to router via wifi. Now both your printer and tab will be on same network and you can still able to print without the need of wifi on the printer.
I have suggested below models considering your need for wifi,
1. B/W Single Function: https://epsonshop.co.in/epson-m105-inktank-printer.html
2. Color multi function: https://epsonshop.co.in/ecotank-l3150-wi-fi-all-in-one-ink-tank-printer.html
3. Color multi function: https://www.hp.com/in-en/shop/hp-smart-tank-515-wireless-all-in-one-1tj09a.html
Came to my sisters house and saw your query about printer.. My sister has this canon ink jet printer.. Not really qualified about printers as such. But whenever I have used this have not faced any problems as such. Connceted to laptops /phones and served well from 2019 till date.
It's canon pixma E4270..
Hope this helps you in any way in deciding.
Status
