- 3 Nov 2010
- 7
This application allows you to access some of native android options on your MIUI installed device which is been hidden by the manufacturer. These options help you get full control over your device such as disabling some pre installed applications, using private dns to avoid ads (Android10/9), adjust modem config to enable vowifi (Android10/9), testing and calibrating hardware tools etc.
Hidden Settings for MIUI - Apps on Google Play
