• Welcome to OnlyTech Forums
    Log in or Register
Helpline : System Restore
5 Aug 2011
Private message on our forum by Jenith, SMOD...
Problem : Hye biswajit sir.
I have a query, That If I have created a restore point on windows 7 os in case many softwares havent setup files, I mean deleted setup files after installing softwares.
So in this case if i format my computer and use restore point then Will I get all those softwares reinstalled which havent setup files?
Advanced thanks.
Solution : System restore facility doesnt require set up files to be present for making the system restore to a previous date.. Yes of course system restore wont fetch you up with the softwares which have been installed after the date that you are restoring to.
Thanks...
biswajit.HD
5 Aug 2011
Ya if u format ur system, system restore wont work, all files will be deleted.. forgot to tell this... thanks mystic.... :)
