Best streaming device for Sony LCD TV
  • Replies Replies: Replies 8
  • Views Views: Views 484
hike
1 Aug 2014
I've tried fire stick on Sony LCD TV but it didn't work accordingly. Could you please help me out to get the best for LCD TV.
I guess, you have non-smart tv. So, in my opinion, Xiaomi Set-top-box is best for you.
What problem is FireTV Stick giving? Can you please specify?
In case of streaming boxes and sticks, the role of TV is just to display what's being fed through the HDMI. Basically, it works only as a monitor. All the streaming, processing, and hard work is done by the stick/box. Unless there's something wrong with the TV's HDMI port, there shouldn't be any problem.
Get a LED TV. LCD is too outdated.
Yes bro. Buying a STB is no use..
Especially Android boxes from DTH Companies. You have to do monthly Rs.153 to keep box active. Fire tv stick Rs.2000+ is best choice...
On fire tv stick, i was thinking of buying it as it have a Non-smart Tv. How is the UI of firetv stick. Also, do we get original firetv stick remote if the remote fails. Is firetv stick worth buying? thanks for your response.
The UI is poor. It is full of ads and bloat. But sadly in India, we don't have any other option in budget. In US, they have various alternatives like Nvidia Shield, ONN, Roku and Google TV Streamer. In India FireTV Stick is your best bet. But if you have high budget, you can buy Apple TV Box. That's the best in terms of UI and experience. There used to be Mi TV Box & Stick, but those have been discontinued now.
