• Welcome to OnlyTech Forums
    Log in or Register
Top 10 Nokia secret codes
Dileep Kumar
8 Jul 2013
find out the phone’s Software version. Code:*#0000#.You will get the software version & date created displayed on the screen.
To find the phone’s IMEI (International Mobile Equipment Identity Code) code:*#06#.
Code:*#92702689#will You can check phone’s exact release date from the factory Also the repaired dates of the phone, if the case.
Code:*4720#this will turn on the half rate transmission. This will make your phone use only half of the bandwidth, but will have a negative effect on the on call sound quality. To turn it off again use same code.
If your Symbian phone is not having a special option that allows users to display or turn off the carrier’s logo.CODE:*#67705646#.
Check clock status of the SIM card inside the phone. CODE:*#746085685#. Note : Only available on some Nokia phones.
Symbian phone allows a soft reset command without browsing for it in the main menu ,CODE:*#7370#to soft format the memory of the phone.
you may face troubles with the phone’s Bluetooth connection and you need to find the MAC address, simply use CODE:*#2820#. Note : Your must support Bluetooth connectivity.
Use CODE:*#30#to see a private number in case someone is calling you and uses this feature.
If you want to apply RESTORE FACTORY SETTINGS use*#7780#. this will reset the phone to factory defaults and comes in handy when you make changes in the phone’s settings
