Suggest a wired fibre connection Airtel or Jio?
  • Thread starter Thread starter Sumit05
  • Replies Replies: Replies 1
  • Views Views: Views 85
Sumit05
11 May 2016
I want a 100 mbps connection with live tv and ott.I have a 55 inch 4k tv.At present i have local isp with tata sky connection.I too have a ps5.So suggest best plan from airtel or jio.
Thanks.:)
For gaming its always better to get wired fibre connection
As per my experience both airtel and jio are best if its wired fibre. But comparitively airtel is best for gaming (ping is low) as you will be using for gaming on ps5 my suggestion is go with airtel with its iptv set top box
