Power Backup Device for Dell AIO PC
  • Thread starter Thread starter DTH Fan
  • Replies Replies: Replies 17
  • Views Views: Views 1,906
DTH Fan
11 Aug 2013
Hello everyone
Recently I purchased Dell 23" AIO PC which is an excellent PC. I'm pretty much satisfied with it. :)
But there is one problem which is not actually any issue in PC but an issue with my habits.
Previously I was using a Dell laptop so I never had to worry about the power backup as it contained batteries. But this new AIO PC doesnt contain any battery backup which is obvious.
So I want to have a small device which can be connected between my AIO PC power plug and main switchboard to provide some battery backup.
I dont want to use a big UPS. I just want to use a small device (small sized like adapter/pen drives) which can provide little power backup in which I can shut down the PC. That's it.
Are there any such small devices available?
Thanks in advance.
Any help guys? I just want a small device which can be connected between AIO PC and main switch and which can charge itself or collect power in it so that once power goes off, it can start giving power to PC. I just want a small size solution.
Bro,small battery(UPS Power Back Up System for Desktop Computer) is also available in electronics & U can try this
connect it with the inverter.
but bro using pc in inverter, battery life is fully reduce & because my inverter life is reduced & i have purchased new battery :shy
bro... he needs it just to shut it down
so for shutting it down , i don't think that the battery is going to b affected.
just shut down means no problem, but inverter cost Rs.10,000 above & Ups for pc is Just Rs.1000 Onwards
bro.... he must b having inverter or generator at home
in india generally people have inverters at home (for electricity back up)
so he can save 1000 rs. also bcoz in his first thread he clearly mentioned that he needs it only for shutt down.
Bro, he told I dont want to use a big UPS. that is the reason
bro, if he using inverter or generator means this ups don't need ,if he using pc while power cuts means ups for pc compulsary:tup
