Seeking Help Please help me to decide Redmi Note 4 vs Redmi 4.
  • Thread starter Thread starter Sumit05
  • Replies Replies: Replies 6
  • Views Views: Views 589
Sumit05
11 May 2016
Guys help me decide which one to buy RN4 3 gb or R4 3 gb version.Which is more value for money?
Redmi note 4 - 11k
Redmi 4 - 9k
Redmi note 4 - 11k
Redmi 4 - 9k
It's depends upto ur requirements dude like battery life and processor and all. If your budget is good then no doubt Note 4 if not that much Redmi4 both phones are value for money.
2 things: Size & Budget. Rest doesn't matter.
If you want a phone that can be operated using 1 hand, looks good & tight on budget, then Redmi 4.
If you want a larger screen, budget can be extended, go for Note 4.
Performance won't matter, both will give good real world performance. Battery will be a bit higher on Redmi 4 due to smaller screen.
