OPPO unveiled its entry-level A37 smartphone for global markets earlier. Now it has launched the smartphone in India. It has a 5-inch HD screen with 2.5D arc edge glass, is powered by a quad-core Snapdragon 410 SoC, runs on Android 5.1 (Lollipop) with ColorOS 3.0, comes with a 8-megapixel rear camera with LED flash and a 5-megapixel front-facing camera.
It has dual (nano) SIM support with dedicated SIM and microSD slots in a single tray. It also comes with 4G LTE connectivity and packs a 2630mAh built-in battery.
OPPO A37 specifications
5-inch (1280 x 720 pixels) HD IPS 2.5D curved glass display with Corning Gorilla Glass 4 protection
1.2 GHz Quad-Core 64-bit Qualcomm Snapdragon 410 (MSM8916) processor with Adreno 306 GPU
2GB LPDDR3 RAM, 16GB internal memory, expandable memory up to 128GB with micro SD
ColorOS 3.0 based on Android 5.1 (Lollipop)
Dual SIM
8MP rear camera with LED Flash, f/2.2 aperture, 1/3.2-inch BSI sensor,1.4μm pixel size, 1080p video recording
5MP front camera with f/2.2 aperture, 1.4μm pixel size, 1/4-inch sensor, OmniBSI+
Dimensions: 143.1×71×7.68mm; Weight: 136g
3.5mm audio jack, Dirac HD sound
4G LTE / 3G HSPA+, WiFi 802.11 b/g/n, Bluetooth 4.0, GPS
The OPPO A37 comes in Gold and Grey colors in India and is priced at Rs. 11,990. It will be available through online and offline stores starting from July 1st.
OPPO A37 with 5-inch display, 4G LTE, 7.6mm slim body launched in India for Rs. 11990
Dual SIM
