Chinese manufacturer ZTE has launched the Nubia Z9 mini under a separate Nubia sub-brand. It was originally introduced in China earlier this year and packs a 5-inch (1920 x 1080 pixels) Full HD CGS (Continuous Grain Silicon) OGS display with 74.1% screen-to-body ratio, is powered by an Octa-Core Snapdragon 615 SoC and runs on Android 5.0 (Lollipop) with nubia UI 2.8. It has 16-megapixel rear camera with Sony Exmor RS sensor, 6p lenses, LED flash and a 8-megapixel front-facing camera with 80-degree wide-angle lens with NeoVision 5.0 Camera UI.
ZTE nubia Z9 mini
It has support for TD-LTE 2300MHz (Band 40) and FDD-LTE 1800MHz (Band 3) for India. The smartphone has aircraft grade alloy frame and glass finish on the back.
nubia Z9 mini specifications
5-inch (1920 x 1080 pixels) Full HD CGS, OGS display with Corning Gorilla Glass 3 protection
Octa-Core 64-bit Qualcomm Snapdragon 615 (4×1.5GHz + 4×1.0GHz) processor with 550 MHz Adreno 405 GPU
2GB RAM, 16GB internal storage, expandable memory up to 128GB with microSD
Dual nano SIM
Dimension: : 141.3 x 69.8 x 8.1mm and weighs 145g
16MP camera with LED Flash, Sony IMX234 Exmor RS sensor, f/2.0 aperture and 6P lenses
8MP front-facing camera with Sony IMX179 Exmor R BSI sensor, 80-degree wide viewing angle
4G LTE, Bluetooth 4.0, WiFi 802.11 b/g/n/ac (Dual Band), GPS/aGPS
3000 mAh battery
The nubia Z9 mini comes in Black color and is priced at Rs. 16,999 in India. It will be exclusively available through Amazon.in starting from today.Nubia Z9 mini launched in India for Rs. 16999
