Noble Skiodo launches 32-inch LED TV with Bluetooth connectivity
  • Replies Replies: Replies 3
  • Views Views: Views 1,849
Noble Skiodo has launched 32CN32P01 HD LED TV with Bluetooth connectivity at Rs 14,999. The TV is exclusively available on Amazon.
It has a pixel resolution of 1366×768, with a viewing angle of 178 degrees. It features a 0 dot screen that eliminates noise.
Noble TV comes with a 10Wx2 sound output. It also has an in-built amplifier that enhances the sound output 5 times. The Bluetooth supports data from USB and other Bluetooth devices.
Noble TV supports MPEG4/H264, VGA Port, 2 HDMI ports, USB port and Digital Media Player. The TV comes with Eco Smart feature that shuts it automatically in case it is not being viewed. It has a customizable backlight option, which consumes less power.
The Epoxy PCB with moisture free components makes the TV resistant of breakdowns due to excess moisture.
Noble Skiodo launches 32-inch LED TV with Bluetooth connectivity | The Indian Express
rahul1117kumar said:
ss of this tv model:
Please don't buy this tv. 2 months back i bought 32" inches Noble Skiodo from amazon. Speakers wasn't working. Remote also not responsive. after replacement same problem. So i got refund and bought Vu.
How's VU and which model you bought? Now they launched more number of Smart TVs.. I am also searching for one TV which can replace my SONY LCD 32"
