naviin0489 Member Joined 14 Apr 2015 Messages 76 Reaction score 41 14 Feb 2020 #1 Does Samsung M20,M30 supports DUAL VOWIFI Stand by ?? Like S9 Plus or Any other phone that supports Dual Vowifi Stand by ??
M mgparmar18plus Member Joined 19 Feb 2015 Messages 275 Reaction score 168 15 Feb 2020 #2 Maybe it's Supported, Because my J6 Supports Dual Volte with Pie update & dual VVowifi with another update. Even if not supported by stock os it will be available after Android 10 update in coming months. (Search for Android 10 update Schedule For Galaxy's.) Last edited: 15 Feb 2020
naviin0489 Member Joined 14 Apr 2015 Messages 76 Reaction score 41 15 Feb 2020 #3 mgparmar18plus said: Maybe it's Supported, Because my J6 Supports Dual Volte with Pie update & dual VVowifi with another update. Even if not supported by stock os it will be available after Android 10 update in coming months. (Search for Android 10 update Schedule For Galaxy's.) Click to expand... ok thanks in j6 are you using Both AIRTEL and jio ?? For Dual VoWiFi??
S Shantanu Member Joined 24 Mar 2016 Messages 927 Reaction score 1,813 15 Feb 2020 #4 It does support Dual VoWifi. I remember using it for both airtel and jio.
naviin0489 Member Joined 14 Apr 2015 Messages 76 Reaction score 41 15 Feb 2020 #5 Shantanu said: It does support Dual VoWifi. I remember using it for both airtel and jio. Click to expand... Are you saying in M20?? Because I am planning to buy M20 to use for Vowifi for both AIRTEL AND JIO
M mgparmar18plus Member Joined 19 Feb 2015 Messages 275 Reaction score 168 15 Feb 2020 #6 naviin0489 said: ok thanks in j6 are you using Both AIRTEL and jio ?? For Dual VoWiFi?? Click to expand... Both Airtel
M meetdilip Member Joined 30 Oct 2011 Messages 235 Reaction score 92 15 Feb 2020 #7 naviin0489 said: Are you saying in M20?? Click to expand... Don't buy. Hangs all the time after Android 10 update.
naviin0489 Member Joined 14 Apr 2015 Messages 76 Reaction score 41 15 Feb 2020 #8 meetdilip said: Don't buy. Hangs all the time after Android 10 update. Click to expand... How many gb RAM are you using. I am just going to buy for lite usage not heavy usage..Did you get dual vowifi standby after Android update?? In M20
M meetdilip Member Joined 30 Oct 2011 Messages 235 Reaction score 92 15 Feb 2020 #9 naviin0489 said: How many gb RAM are you using. Click to expand... I will tell you tomorrow. Costs around 12k naviin0489 said: Did you get dual vowifi standby after Android update?? Click to expand... I don't use VoWiFi. After Android update, I cannot even make calls properly. I don't game or anything. Mostly calls and YouTube.
