Enable Right Click on a site which sites disable
  • Thread starter Thread starter Napster
  • Views Views: Views 1,357
Napster
7 Apr 2011
here is the steeps>>>>>>>>>>>
Lots
of web sites have disabled the right click function of the mouse
button... it's really, really annoying. This is done so that you don't
steal (via right-click->save picture) their photos or images or any
other goodies. Unfortunately, it disables ALL right-click functionality:
copy, paste, open in new window.
It's easy to change, assuming your using IE 7:
Click "Tools"->"Internet Options"
Click the "Security" tab
Click "Custom Level"
Scroll down to the "Scripting" section
Set "Active Scripting" to "disable"
Click "Ok" a couple of times.
You'll probably want to turn this back to "enable" when your done... 'cause generally the javascript enhances a website.
On mozilla firefox, disable javascript option by going to tools menu -
option - content - unchek 'enable javascript - ok...........
To re-enable it follow the same procedure and chek on 'enable javascript' option!!!
