At the iPhone SE and new iPad Pro event, Apple also introduced a new Lightning to USB-C Cable that lets 12.9-inch iPad Pro users to take advantage of faster charging using its new 29W USB-C Power Adapter. The Lightning to USB-C Cable comes in 1m and 2m in length.
According to Apple, the cable can only be used with an Apple 29W USB-C Power Adapter to take advantage of the fast charging feature on the 12.9-inch iPad Pro, so it doesn’t work on the new 9.7-inch iPad Pro. You already have a 29w USB-C Power Adapter if you own a 12-inch MacBook. The Lightning to USB-C cable lets you plug directly into your MacBook for syncing.
The Apple Lightning to USB-C Cable (1 m.) costs Rs, 2300 and the 2 m. option is priced at Rs. 2900. The Apple 29W USB-C Power Adapter costs Rs. 4100. These are priced at $25, $35 and $49 in the US, respectively. These new accessories will be available in the next few weeks in India.
Apple Lightning to USB-C Cable for faster 12.9″ iPad Pro charging starts at Rs. 2300
