Any liquid there to clean led screen
  • Thread starter Thread starter prakash_Tv
  • Replies Replies: Replies 7
  • Views Views: Views 1,659
RE: Any liquid there to cleaning led screen
Clear With dettol,
note> try on you own risk, i use it to clear my CRT TV with wet cloth.
:d
If he try on his own then why r u suggesting
Sbhopale said:
Clear With dettol,
hey r u joking man ??:huh:huh
prakash_Tv said:
Sbhopale said:
Clear With dettol,
with dettol, look like new one, and yes dont know whether it harmfull for led or not but yes not harm to CRT tv
Sbhopale said:
prakash_Tv said:
Sbhopale said:
Clear With dettol,
lot of different's between CRT TV and LED TV. LED TV very soft screen and CRT TV its like a glass screen. :lol:lol:no:no
Follow instructions laid down in user manual. Any experiment would harm the panel. I use plain water sprinkeled on the soft cloth supplied by manufacturer. Not much water and never press the panel while cleaning. Regular cleaning with dry cloth. Dont use chemicals for cleaning the panel
ok ok:)
