Antec Eleven Hundred gaming cabinet launched in India, at Rs. 7,400
  • Thread starter Thread starter Biswajit.HD
  • Replies Replies: Replies 1
  • Views Views: Views 1,770
5 Aug 2011
Antec has launched the Eleven Hundred cabinet in India, part of its Gaming Series of products. It has been designed to offer enhanced expandability, cooling and convenience features, and is meant for gamers “seeking the highest level of performance.” Antec has given the Eleven Hundred an MSRP of Rs. 7,400, and it is available through select major retailers, online retailers and distributors.
The Antec Eleven Hundred gaming cabinet features support for XL-ATX sized motherboards and four-way GPU configurations. As such, it boasts of the highest expandability of any Antec chassis.
The Antec Eleven Hundred comes with default 200mm top and 120mm rear fans, mounts for up to seven more fans for advanced GPU and hard drive cooling, including a 120 mm intake fan behind the motherboard tray to cool the CPU. Users can also utilize the included fan power hub to connect up to four 3-pin fans to a single Molex for improved cable management.
Antec has given the Eleven Hundred cabinet tool-less 5.25-inch and 3.5-inch drive bays, and features up to 36mm of cable routing space and grommet-lined cable routing holes. The Eleven Hundred’s PSU intake & front air filters can be removed without taking off the side panel or tipping the case.
Source : Digit
